luggage rack
railroad
Does anyone have any suggestions on finding a small luggage rack like on the trunk lids of some convertibles? I am thinking about adding one to the turtle deck on the T for hauling some misc. There is NO room inside the T.
thanks
railroad
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000036b~Z5Z5Z595407~P189.95~~~~~~~F
yb.dll
Here is on on a vette I bet some one could weld you one out of stainless rod easy.this is the link to it
Try JC Whitney. I bought one many years ago for the back of my Bugeye Sprite, it was just about the right size for a T. Or find an Austin Healey website and check there.
Bruce
That HD rack looks good. I guess, I'll have to go by the HD shop to get some dimensions. JC Whit also had a decent looking one, also chrome. It's about
half the price of the HD, but I'll bet the chrome and quality are not the same.
Thanks for the help
railroad
railroad said:
Bruce
Thanks for the help
railroad
I will save you the trip. When I saw your post, my first thought was an HD rack since I have one on my HD Ultra Classic. It measures 20 1/2" wide x 14" front to back x 4" in height. The mounting points (4) are 12 1/2" x 8" c-c. I hope that this helps...
Thanks for the information. I have let the body down without installing a rack. With fall coming fast, I needed to get it out of the garage. I bought a new gas tank from Ron to have some clearance for the rear axle travel. While I was under there, the rear cross member and spring perch looked risky. So out comes the sawzall and in goes a new crossmember and perch. I had the body blocked up where I could work under the turtledeck. At some point, I will have to remove the body completely and hope to correct all the issues with the T. It will definitely need a rack. I wrote down the dimensions, so I can find them in 2 places. Getting older everyday. I got everything hooked up and made a drive out across the field. The left front grabs and the right sticks. I pulled them both down and will have the shoes relined tomorrow. I think they are 40 something truck brakes (Ford). The wheel cylinders have 1 3/8 cups on the front and I think 1" on the rear. I already had new cups, covers and springs. I had washed the shoes in brake cleaner due to a leak before I owned the car. The shoe lining started falling apart.
Anyway thanks again for the help.
railroad
I had custom luggage strap mts made for mine. I put the luggage on the padded bed cover and strap it down.
