boseefus402
I have a 28-29 1 piece roadster shell, kind of an altered dragster thing but a little heavier.
I want to put in a roll bar, a front hoop right behind the firewall, and a few downbars, nothing NHRA legal which is impossible to do without it looking like garbage, just a little safety.
What do you do for a floor and body reinforcements then? The cage basically kills the plywood floor being glassed in. My only thought was to reinforce it with 1" steel square tubing, fiberglass that to the body, and then bolt the body to the frame with some steel connector plates. After its bolted on, weld or sheet metal screw on a sheet metal floor.
Any other ideas? If i stick with the square tubing, can you structurally bond steel to glass? What do you use? Just rough up both then go at it with matt and resin? It's not like wood where it will just soak in and bond.
