Mounting jag rearend
Sputnic
I saw a post from awhile back about mounting a jag rear end. I'm needing to know how much kick up is needed in frame to corrispond with front end height?
Also the best width for the frame rail across rear end?
After some searching on the boards,I did find some good info.
Was wondering if anybody has used large diameter wheels with back spacing to clear control arm? If so what size, and back spacing didi you use?
How about the correct way to narrow the Jag IRS?
