Mykk
Did I mention Scatter Brained? Yeah, it's tough to focus on one piece at a time when you're on a parts hold for the existing projects in work and there is so much to do.
Today I decided to mock up the offset Euro stripe with painters tape. To keep the stripe on the grill the outer edge of the stripe should be roughly 8" from center. That 8" from center made for a stripe a little to centered on the tub. So I decided to experiment with a little forced perception, with intention of keeping the outer edge of the stripe 8" from center on the grill, 9" from center on the cowl and 10" from center on the rear while keeping the stripe straight. We'll see how it goes. I also learned I should use the laser for the vertical lines instead of measuring off center otherwise the stripes bow out with the shape of the tub.
