joshuawcolvey
I do believe this is the spring i need Speedway 910330030 $74.99.
The Shackle Speedway 91033323-ZINC $19.99.
I found Spring perch's but not spring purch pins?
Tie rod ends i do belive at speedway , but dont know if RH, LH threads $40.00.
Weld in LH,RH bungs Speedway 91002965- $20.00 for 2
Look for a stock wish bone, it's shaped like a 'U'. The open end has clevis' that the axle fits into and there will be a ball on the other end that goes into a socket on a stock chassis
Not sure about this or were to find one?
So far about 155 in parts, nit to shabby thank you sir.. you can PM me if you like..
Thank you so much...
