Make sure you have 12 volts to the correct pin on the distributor.
There are wires under the coil, between it and the distributor cap, and those are the wires that run from the coil to the square recepticle on the cap, where the battery(ignition switch) wire and the tach wire connect. That was what I was referring to, sorry if I muddied the water! It bothers me that the voltage drops to six volts at the coil. That's why I suggested running a jumper from the battery direct to the ignition wire on the cap to determine if there is a short or bad connection in the ignition circuit, before the distributor. If you are sure that the coil is ok, and the module tested ok, if you have a solid battery source, the pick up under in the distributor is really all that's left. The reason I keep asking if you have a tach signal is that is driven by the pick up. The pick up is under the part of the distributor shaft with the weights on it and if my memory serves me right, you have to remove the distributor and remove the gear, then remove the shaft from the top to get to the pick up. It's been a while since I worked on one, but I pretty sure I'm right. If you aren't familiar with doing things with the distributor, be sure to make marks to make re installation easier, like firing order, base timing, and oil pump drive. You can test that pickup coil with an ohm meter, it should have between .687 and .999 k ohms between the two wires and neither one of them should be shorted to ground, meaning testing each one to ground should be open. There are some u tube tutorials that cover this if you have access. It may be clearer for you than my attempt to explain it, I'm better at doing than describing sometimes.Fletcherson - I guess I am a bit confused. Other than plug and coil wires, the only wires running to the dist are two wires from the Ignition Module. Am I missing something?
I did change the coil out and there was no change.
If you have a 12 volt test light, you can connect the ground side, the alligator clip, to the battery source, 12 volts. Then touch the tach terminal on the distributor cap with the probe and crank the engine over like you are trying to start it. If there is blinking light, that is normal, that's a tach signal, if no blinking light, either the pickup coil or the module is faulty. It really doesn't matter which end of the light you connect to the terminals, whichever is easier.No tach since the car is not running - or are you referring to the speed the engine is turning with just the starter?
Battery cables are correct.
I, too, attended that event and met some really great people. I'm glad to see that your problem was solved so quickly, rbsWELDER., so that you could enjoy all the scheduled cruises that were there in Ocala.I trailer-ed the T to the NTBA Ocala event last week and I am very pleased and very embarrassed by the events that unfolded. Long story short, it was a loose wire, which one of our members, 'Cuz', found in record time. All is good!
Happy ending, we had many great cruises in Ocala/Daytona Beach!!!
