I had a little energy left after work this evening, so I spent a couple hours in the garage playing with sheet metal. I began by cutting out two matched pieces of 3/4" plywood in the size of the filter OD. a piece of 18 guage sheet metal was cut about 3/8" larger than the plywood, and then the whole sandwich was drilled at the location of the center of the future intake pipes (show earlier).
once bolted together, the edge was hammered over to form the flange. a few cuts were required at the curved ends, but I just let them form a lap joint and hammered it all down as smooth as I could.
After some minor finish body work, the lap joints at the ends were welded, then the edge was ground smooth with a flap disk on my side grinder. this is as far as I got this evening.
both of the plates I made this evening will actually become base plates, so I may make similar ones for the covers, or perhaps use 3/16" aluminum to fabricate some. no sence planning too far ahead I say.
Cheers,
Russ
Cheers,
Russ
