Gerry
It's been a wile since I've posted, but work has been slowly going on with the T. The wife is out of town for most of the weekend, so more than usual should be accomplished this weekend in fact :hooray: . I set up a piece of plywood to simulate a portion of the floor, along with it's wire exit opening etc., to make it easier to lay out where everything was going to fit the best. the body is back on now, and all the wiring except for the under dash stuff is now done, but the wife took my camera with her, so this is the latest pic I have however.![]()
I had a very vivid mental image of what I wanted in the way of tail lights, but for the past several weeks I was unable to actually make them materialize. slowly but surely I've gathered all the bits needed to accomplish my goal however, and I'm pretty stoked about getting that behind me and moving on. what I envisioned was a look similar to the late 60's GTO tail lights. for the lens I found a set of new 70s GM side marrker lights that were just the right size for my T tail light application, but of course they were set up with a very small single element bulb which was totally unsuitable for tail/turn/brake lights. I did, however, have a set of old trailer lights that were willing to give there all to the cause. by cutting the mid section out of the trailer light lense and cutting out most of the back of the marker lights, I was able to graft the two together to come up with a very workable set of light assemblies that have just the look I was after. I'll cut openings in each side of the tailgate to allow only the lens portion to show through, and become flush with the tailgate surface. wala!
moving...... forward....... slowly,
Russ
Hi Russ
good to see more pics. I think its too late and you know what you want, but how about this.
Maplins (I think the US equivalent is Radio Shack) do LEDS with a power limited that takes between 3 and 30 volts input. Its about the size of your small finger nail and come complete with the LED attached. You could make up ANY shape of light you want with any number of these. Its the way Im going on mine.
Only problem is they are not cheap if you need 30 of them Also you can get standard and ultra bright red LEDs so tail and brake light are easy
Just a thought for the future. Just imagine your tail lights in the shape of a 23T Bucket shinin in the night
Gerry
