tfeverfred
Today I installed a transmission cooler that I found at the local Auto Bone. It looks like a good spot for it. There is a 1/2" gap between the cooler and the frame to allow the fuel line to pass behind it. I fabricated the brackets from aluminum and used thin pads to cushion the cooling fins from the brackets. It looks like it will work. The bottom portion of the cooler (about 2") is barely visable from a side view, but looks right at place for a home built hot rod. What do you guys think?
Also, I cut the ends off a pair of 26" extentions (too long anyway) that were given to me. They're not as shiney as the rest of the exhaust, but they are close and FREE. I really like the look, but a friend mentioned that the heat coming from them may be too much for the rear brakes and lines that are on the rearend. The distance from the exhaust exit to the rear tire is about 6" (it routes BEHIND the tire) and about 20" from the rearend tube. I don't think it should be a problem and need some opinions on this as well.
If these don't work, I'll just give up the cash for the 20" extentions with turnouts.
