Quezzmo
If I nail it from a stop or slow roll it will die. If I take off with normal throttle pressure it stumbles momentarily then launches. I have a Holley 470 with a 50 cc accelerator pump with the factory .031 squirter and right now it has a orange pump cam in it. It's on a mild 350 with a Holley Red electric pump with a regulator set to 5 psi. Dual plane intake and a .462/.469 cam. I should be around 300 hp. I'm ordering a pump cam assortment. Should I order some different squirt nozzles also? Was installing the 50 cc pump a mistake? Thanks, Tom
