Ok here are some photos of where I am at. My radiator is about 2 inches too high to make the body cowl line match the grill shell. this is right even the bottom of the frame mounting. I like the pump position as I could run a conventional fan. It it about 1 inch off center. I have to drop the mounting about 2 inches and go to an electric fan to make the cowl and grill lines match up. I am going to post the following pics. I would like your opinions as to which way you all think I should go at this piont. the radiator mounting is about the last thing I need to get worked out. before finish welding and painting the frame.
