I guess I should qualify my statement. The Spirit body will fit fine assuming the body sits on the frame with the same spacing as on a Spirit frame. If you have other than a Spirit frame (Spirit dimensions), it may not fit.Lee_in_KC said:The Spirit body fits fine with those tabs in place. I have a Spirit body and frame.
Ted Brown said:Any time you are working with Alum.. remember to have the wax handy, if you want to cut or grind, Wax up the cutter or grinding pad first, this will make things work almost like steel, no clogging of the cutter or grinding disk, WD 40 works as well, just spray the disk now and then, or the saw blade, cutter?? everything... speeds things up real nice... :rofl:
Lee_in_KC said:I guess I should qualify my statement. The Spirit body will fit fine assuming the body sits on the frame with the same spacing as on a Spirit frame. If you have other than a Spirit frame (Spirit dimensions), it may not fit.
Why dont you put copies up for auction of the Shade Tree build?I watched that and i thought it was real informative for someone new to T-BucketsMr T Bucket said:I'll have to find my copy of the Shadetree Mechanic build of a Total T. I'm pretty sure they had to cut them off.* No tabs on my C4, LOL.
* Individual results may vary.
Ted Brown said:I try and leave them on till last thing, you never know what you may want to hook to them, as they are nice and strong to boot.![]()
Rick said:Why dont you put copies up for auction of the Shade Tree build?I watched that and i thought it was real informative for someone new to T-Buckets
