sschutze
With the new axle being 5" narrower and having a 4" drop I have found that my steering cross rod will no longer fit, it runs through the same area my radiator needs to be. I'll have to convert to a front steer. I know some of you don't like that, but I don't see another option without buying a new radiator. The radiator sits down between the frame rails about 5 inches.
I started to set the engine in place today, found I only have 1 1/2" of ground clearance with the old motor mounts. I knew I was going to have to raise the engine, but this is causing me more problems. I was hoping to get at least 4 1/2" of clearance under the pan just like the front axle. But with it raised that much the upper rad hose is in the way of the fan. I'll have to raise the radiator 4" too, then raise the grille shell, I'm affraid that will look goofy.
