Try setting initial advance @ 16*, all in by 2500 rpms, shoot for 36 - 38 * total, hook up the vacuum advance (for better fuel economy [with these fuel prices an extra couple mpg won't hurt]).
2820 lbs., 3000 lbs. w/you in the driver's seat is about 1000 lbs heavier than the average T. That's a real difference. I think more horse puppies are in order.
Any way, get the timing figured out first. Then attack the carb. 600 cfm is fine for that engine. Is the carb stock? Is it second hand and seen a few owners? Find out what stock settings are and use that as a staring point.
What is the loaded diameter of the rear tire? Maybe a shorter (or narrower) tire is in order.
You didn't say how the car runs. Get the ignition fixed first, then the carb. If you can't do a huge smoky, there are worse things in life.
If you want to do burnouts, then more H.P. will be required.
2x Ruggs request for pics.
This is where "tuning" comes into play. 90% of carb problems are in the ignition.
John
