KPoole9008
I have an all steel C Cab that I used alot of TBucket info to build. It has a GM Performance crate engine with 290 hp, timed at 10 degrees with 32 degrees advance, a Holley 600 cfm carb with vacuum secondaries, a Performer intake, a Mallory Unilite distributor with their coil, and headers. The tranny is a Turbo 400 with a 2000-2200 stall speed torque converter. The total weight of the car is 2820 with 1060 on the front axle and 1760 on the rear. The rearend is a 3:42 ratio. I am running B.F. Goodrich T/A 2.75/60/15 radial tires on the rear. I can't get the rear tires to break loose no matter how hard I try. I've even put a linelock on the front brakes and with it engaged the front tires slide. Any ideas why it's so slow out of the hole.
