You won't go wrong with Accels. You can't beat their short wire runs and machine-crimped connectors with cut-your-own. Fancy wires won't increase performance, but they may last longer. But 2 sets of Accel is still cheaper.The whole reason I started this thread was because of the Taylor brand as I had never heard of them! I searched the web for Taylor reviews and the feed back was about 50/50, so the search was on. I've looked at MSD but way to expensive and only comes in black and red. I've narrowed it down to Accel, Moroso and the Taylors. The only thing I was really looking for was 8mm universal (trim able), blue wire and 90 degree plug ends. So now I just need to decide between the three. Ben, that is a great idea with the removal of the writing. I too have been going out of my way to keep names of this thing until they start pitching in either money or start busting their knuckles.
I run the Taylor wires as well, nice fit without a lot of slack.
I was planning on "cutting my own" but I came to the realization that I could not make them any better.
Use silicone spray and the boots will slide back and forth with ease.
Not to start an argument, but that definitely wasn't the case with the wires I bought. I tried silicone spray, Teflon dry lube and WD-40 (the WD-40 worked best). So much force was required to insert the wires into the right-angle boots, I was afraid I was damaging the wires. I even had to put on leather shop gloves because my hands kept slipping up the wire. Just my $.02...
I spray the wire as well as the boot to help.
