Screaming Metal
Hey Lee, My DCR came out to 6.5 , I'm running a Comp Cams 12-404-4 blower cam. My Static CR is 8.1:1. I'm running KB Forge blower pistons with the -18cc dish. The heads are the Edelbrock Performer RPM aluminum heads with 70cc chambers.
I tried to email the guy that wrote the article and ask about the effects of a blower on his calculations, but the email address he has listed is bad. I did read another article that mentioned the VE while running a blower is about 115% if it's overdriven. I'm running mine 1:1 right now. ever since switched to EFI , I haven't been able to get a good idle and the engine seems to run rough, at least to me. I'm running 93 Octane with Octane boost and it still seems to me that it struggles to run smooth. Almost like the CR is too low even with the blower on it. At some point while we were tuning on it, we must have got it too hot or got too much pressure in the crank case because both front and rear seals are leaking pretty good. I figured if I was going to have to pull it out and replace the seals I'd look at maybe a cam swap and switching to a crank trigger for the ECU.
This close to Christmas, things tend to slow down at work, so I was trying to do some research to find a solution. I've gone through every HP book I have, which is quite a few and re-read the 3 books on Supercharging I have trying to find some answers.
Even the tech that was helping me tune it back in October, said it didn't sound like it had enough CR in it. He could hear the exhaust over the phone and said it didn't sound right. LOL I pulled the plugs and they were all over the place. I'm running those new E3 plugs and it just about every other one was sooty black while the others were nice and brown. I've had a few other folks look at it too, and we're all shaking our heads. I know I'll figure it out, eventually. I just have to find the right combination for the EFI and blower.
Hey, on your tuning problem....What type of ignition are you running and did you degree in your cam? Just trying to help you solve your dilemma....sounds like a simple problem. Blower motors are funny like that....they love low compression....but too high, they will definitely let you know about it. Also, what size is your blower and when you romp on it, at what RPM do you see boost pressure on your guage?
