Steering is complete.  Yes its scale you are seeing.  I was told it would be just fine using the stuff I am using that's why I used 3/8's stock.
On to the pics:
I finished up the arms, made up my tierod, mounted the steering box and made the drag link.  I used 1 inch .219 wall DOM for the tierod/drag link.
Drag link is parallel to the hairpins:  sitting at 5 degrees right now, Once I get a different spring things should level out a bit more
Everything clears throughout the range of motion.  Though I will have to work on some steering stops, it tags the shackle at full lock.
Drivers side:
Passenger side:
Its finally starting to look like something other then a pile of parts
