Mr. Fixit
Some time ago I posted a thread regarding the fact that my steering linkage rod hits the shackles when fully turned left or right. Now that I am reassembling the chassis/steering components after some paint and chrome, and since I have never resolved the contact/interference issue, I am wondering if anyone has ever shortened their Pittman arm to limit the travel of the steering? Thoughts??
Also, I came across an older NTBA tech article regarding bump steer which concerned me. It stated that "in order to avoid bump steer" in a conventional steering setup, the Pittman arm needs to be completely vertical when the wheels are straight and the drag link needs to be 90 degrees from the Pittman arm. Mt drag link goes up at quite an angle from the Pittman arm (reversed corvair box mounted to the frame rail) to the steering arm. Here is the link from the NTBA. http://www.nationaltbucketalliance.com/tech_info/chassis/turning/steering.asp
Is the drag link always 90 degrees to the Pittman?
Thanks..
Thanks..
