Lee_in_KC
An adjustable bar would have rod ends that screw in and out of the bar to adjust the length in small increments, similar to a tie-rod or drag link. The most commonly used rod ends are referred to as "Heims" or "Heim joints." This is what they look like...gsagona said:How can you tell the panhard bar is not adjustable? Also, where would I find one (an adjustable bar) online? Thanks for your help gentlemen!
Finding a pre-fabbed panhard bar that would fit your application is going to be pure dumb luck. You'll probably have to have one made. I would go ahead and take your bar off, flip your shackles, make sure the axle is centered on the frame, measure eye to eye from the frame mounting point to the axle mounting point, then post that measurement here. The chassis experts (I'm not one) should be able to give you a good recommendation on proper length.
