deckofficer
Banned
1790 lbs. with 15 gallons of fuel
Hi AZCOWBO,Mine weighs 1750#.
What tricks did you use to keep the weight so low???
That has to be one wild ride. At our power to weight ratios, I notice a differance just taking a passenger, you are 440 lbs. lighter than me....WOW ! Tell me what it is like to drive in curves and straight line hauling ass.Mine weighs 1350 lbs with 5 gallons of fuel. 4.3L Chevy V6 with T5 and 94 inch wheelbase is the trick I used.
Bob
Mine weighs 200lbs. What difference does it make. 200 to 1000 HP will make these things scoot!!Any of you guys have an idea what a ballpark weight is fo your T buckets using a small block. I'm doing some numbers on my inline engine and need something close. Thanks everyone.
Mike
Makes a huge differance at our power to weight ratios. Just plug the numbers into a 1/4 mile calculator. Example my car weighs 1790 and I weigh 250 for a total of 2040 lbs. At 311 hp to the ground works out to a 10.9 et. The guy that has a car 440 lbs lighter than mine would do a 10.0 et. 9/10's of a second in the 1/4 is a big deal. Should he weigh 100 lbs less than me he would turn a 9.8.Mine weighs 200lbs. What difference does it make. 200 to 1000 HP will make these things scoot!!
It's a blast, like all t Buckets! The best way to describe it is that it's like driving a large Go-Kart! See attached photo.
Bob
With your power to weight ratio with those narrow rear tires you must have to feather the throttle to keep from spinning.Nice looking ride.
