Installed drive shaft and headers waiting on alternator bracket to mount alternator on lower passenger side. Tried 2 different brackets for lower drivers side but couldn;t get enough swing to tighten belt without hitting frame.
Moved battery to under seat and had to build a box to make it work. Was going to put next to gas tank but made things to close even with the battery on it's side.
Pop riveted and panel bonded it in. Also a 1/2" wide piece of 1/8th inch steel under dash on the lip to mount column drop to panel bonded this also.
Worked on deck lid today. Spring loaded needs no prop.
What is the source for those hinges?
Tanks
Mark
