Island Girl
Well . . . . .
After sorting thru and somewhat organizing all the boxes of parts that came with my kit, and marking each box as to contents, I went to put my wheels on to see how the T would look with its own wheels and tires, and while the fronts went on fine, with a nice low look,
The rears weren't so cooperative and need some wheel spacers . . . . I was rather disappointed that they didn't use a wider rear, or ask about the backspace on my wheels.
I have the 15X15 Weld ProStars with 4.5" backspace, which is the least backspace they come in.
With the tire right up against the body, there's still about 3/4" from the axle flange, (actually the brake rotor on the axle flange) to the back side of the wheel.
I'm thinking a minimum of 1.250" of spacer, and possibly nearly twice that to have adequate tire to body clearance . . .
Anyway . . . Summit to the rescue again . . . .
Ordered a couple sets of 1.250" Cal Custom spacers https://www.summitracing.com/parts/CAL-75813 and some lugnuts, so hopefully, next weekend they'll be here and I can see how the T looks with all its wheels in place.
Down the road, I'll be looking at a better alternative, as with that much HP, I really don't like the idea of having to use wheel spacers, especially aluminum ones.
And FWIW, I snagged the last 4 security cables, (linked above) from Home Depot, since they do seem to fit thru the wheel slots and around the brake rotors just fine.
