Coupefreak said:I guessed I missed it.......where did you get the mounts??
I need some of them for my C-cab
Vance
The shock just slides on the lower bar.After taking off the rod end(be sure to count the threads so you get it back the same way)you slide the spreader bar in place then the shock then the rod end the shock rests between the nut on the rod end and the spreader bar.The spreader bar is to stiffen the tyrods.Look in the Total cat.on page 50 and theres a good pic there or go to there web site you can see it there also.Hope this helps.By the way the ride is like a lincoln compared to the friction shocks.Paulski said:Hey Rick
Do you have any pics of how the shock mounts to the hairpin rod? Do you have to cut the bottom bar of the rod shorter and extend the stud to the clevis? Or does the shock bushing just slide over the rod, and what keeps it from sliding around?
That particular one i made on a vert cnc mill but Speedway does have them.ACJC said:Rick, where did you get the front license plate bracket?
