Actually, I think it's the screw that holds the turn signal stalk down to the steering wheel hub. Mine flops around a bit. I think the screw has backed off. Been too lazy to pull the wheel hub off the steering shaft... bit of a chore as you know.putz said:If your directionals don't cancel either steering whell is not straght or you have a broken spring in your directional switch
