AndyMenon
It was not the timing. Some of the inlet valves were open on the compression-ignition stroke.I'm dying to know what the problem is. My money is on the timing.
I really appreciate your response. The motor just fired up this evening. I'm not sure where the *fact* about my distributor moving to the front of my motor originated. I don't recall ever stating that.What do you mean the distributor is in the front. Just joking. I know something like this is frustrating and if the motor is sound we can get him going.
LOL! Sorry about the late response. Some other errands (delegated by the boss) kept me out of the shop for a couple of days. Agreed, that is one long haul!I just hope he gets it started while he still has hair left. I wish 1 person could talk to him on the phone cause from experience alot of people can and will make it worse.
I have an ipad or phone with video chat, This would probably be the easiest way due to someone else could see it live and give input on the subject.
P.S. I actually thought about driving to you ............. Until i mapped it ! Your 1658 miles away and straight through is 25 hours with current traffic.
I will bring the movie. A 30-second clip of my motor firing upYou get the Popcorn,or Peanuts, I'll get the beer....think we can sell tickets?
Thanks so much for all your valuable inputs. The # of pages that this discussion rolled into is a testament to the fact!
That said, I'm not one of those individuals who gives up so easily.
OK, I have pasted pictures just to make sure that I was right about the way I had set up the cam, and that there was nothing extremely out of whack with the set up . I just could not recall all the details as this was all put together back in 2010. Therefore, I had to retrace my steps and this is what I did:
- Gentleman, I am happy to report that my ride has fired up!
- My apologies for the size of the text!
- Please don't ban me from the forums. But the font size reflects the magnitude of my happiness!
- I have made a video on my cell phone and will post the YouTube link here as soon as I sync my phone to my laptop.
- Took off the distributor. Confirmed the position of the timing mark by comparing it with the stock timing cover.
- As mentioned in my post #71 yesterday, I made sure that my TDC-position was indeed the compression-ignition stroke.
- Then, loosened the rocker arm nut for the inlet, and re-tightened the nut 1/2-turn at a time just enough for the push-rod to stop turning, followed by a quick quarter-turn. Further, I made sure that the exhaust valve is closed.
- If #1 was at TDC correctly , it means each cylinder in the firing order would hit compression-ignition for every 90-degrees of the crank rotation.
- Rotated the crank by 90-degrees and repeated the process on each of the inlet valves for each of the cylinders in the firing order 1-8-4-3-6-5-7-2 .
- Reinstalled the distributor pointing to the #1 cylinder and cranked it. It fired up instantly!
Cheers!
Andy
So what do you think it was, distributor off or valves misadjusted or both? Anywho, Good to know it's "alive"Thanks so much for all your valuable inputs. The # of pages that this discussion rolled into is a testament to the fact!
Cheers!
Andy
Thanks! was the inlet valves. there isn't a real easy way to conclude that the inlet valves are closed shut on TDC with the intake manifold bolted on. I must've given them one turn too many.So what do you think it was, distributor off or valves misadjusted or both? Anywho, Good to know it's "alive"
Thanks for speaking my mind bowtie! Yes in retrospect it was not very hard. It was just too time consuming.isn't any one local to him to help him out? it's not that hard...............LOL
I'll open up the valve covers tomorrow and make sure that has not happened.when you tighten down the rockers you can't tighten them till the push rod stops turning by doing that you collapse the lifter past the intended cushion working area and when the lifters pump up you could bend a push rod
The V305 is embossed on the casting of the engine block. It 's on the d-side, near the firewall , on the transmission tunnel surface. The motor was pulled out of the truck from the person I bought it from. It had a stock cover that I posted in the pic. The timing mark is part of the plastic valve cover (that looks hideous, one reason I took it off).YAY IT RUNS....................... But,
the timing mark being on the side means its NOT a 305 sir ! Do you have the numbers on the back of the block by the distributor ?
Yep, in fact she has warned me not to go back into the garage again until tomorrow.Glad to hear you got it going. Way to hang in there!! I really like the stick showing everyone the rotor is pointing to # 1 cylinder. You can actually start with # 1 plug wire anywhere on the distributor cap as long as # 1 is up on compression stroke and rotor is pointing to that position.. Just saying for future reference Anywho like I said glad to hear it's alive. Have a Blessed Day. Is that the Boss calling? LOL
LOL! Thanks much! I will tryNow, we're proud of ya!....do a burn out for us! Hahaha....
Congrats on getting it running! I'm confused about the problem - are you saying the valves were too tight, or was the distributor installed incorrectly (or both)?
Oh, I can help you out with what it means. Take a look at the total number of posts in this thread, which will get you headed in the right direction on what it means. This thread went on for 98, unnecessary posts. And if you don't believe me, just read on.I just saw your response. I am not sure what this means.
