What about a 110v 120 Amp Arc Welder?
I'll go with RPM on the flux core. I just sold my Miller 135 to a buddy It's 120 volt but you can set it up flux core or straight wire with gas. Straight wire with gas is definitly the way to go. Way better looking weld with a little practice and less clean up later. My buddy and I are working a job together tomorrow morning I can ask and maybe you can rent/borrow it from him. Or if ya can get it down here with a few cold beers we could do it for ya! I know my Hobart 187 will whip it out right.
I'll ask Devon in the morning when I see him.
Devon says it's OK with him. I left you a message on your cell with his ph # so you can give him a call and work out the details.
A stick welder is the way to go on heavy metal, but it will burn through thin metal.Don't mean to hijack the thread - but - if you're comfortable with stick welding, is there anything wrong with using that for fabrication work?
