Even though I recently upgraded to suppression-type spark plug wires (Taylor Spiro-Pro's) to replace the solid metal core wires I was using with my Accel breakerless distributor, the ignition control module packed it in.  Fortunately, I was already home from a cruise and in my driveway. Trying to locate a replacement, I have discovered that Accel (Holley) no longer makes this particular module, so I'm stuck with trying to find one on somebody's parts shelf, or replacing the distributor. Any suggestions? (I need a small cap distributor, since there is not enough clearance between the distributor and the firewall for the HEI large cap.)
