What type of headlight?
brubakr
I just picked up a project, and I need to know what type of headlight goes with this type of headlight bracket.
The first thing I thought of was one of the many variations of side mount motorcycle headlights. This just one example of many styles...
http://tinyurl.com/o7b3qa9
Thank you for your replies. It looks like I will be changing the headlight mounts to something a little less expensive. I don't see spending $900 on headlights.
You can always make your own adapters to mount any headlight you want and be different than the rest.
You can make your own. Not all that hard, just figure out where you want the lights to sit, then make some to match.
All it takes is some time! Well a welder helps :)
I made mine using some 1/2" thin wall conduit 90's, some 2" exhaust tubing, a plug from a 2" hole saw and a piece of 1 1/2" angle. The wiring is totally concealed within the conduit for a clean look.
