Which Fan Kit??
Johnny
185 degree kit, or 195 degree kit?? Using small block 350.
Any thoughts on this guys?
Thanks
I used the 185 degree and it works great. I believe a 185 or 195 would be fine. The big trick is to get a fan that moves a lot of air. I am also using a 2 core aluminum radiator.
Denpends on the thermostat you use. if you use a 180 stat get the 190 temp sender otherwise the fans won't shut off after they are actuated.
I used a 16" Spal fan with a Spal 195 relay kit. It seems to work. Today was the 2nd time I had the engine running, 1st time up to temp to make sure it did work.
PaulR
