Gerry
I knew I had this somewhere.
Dated 1989 I found it on my old PC.
For all the guys who have asked about the engine here are the specs as listed by GM
Gerry
ENGINE.
New GM 350 Chevy HO. Part no:10134338 This motor is offered by GM for off road and hot rod applications. All new parts are used to give maximum power with good reliability and low maintenance for a price of $3000. (Mid 1992)
BLOCK: Cast iron 4 bolt with 4" dia bores.
CRANK: Forged steel, one piece rear main seal, 3.48" stroke.
CON RODS. Heat treated, shot peened, forged steel with pressed pins. Pink colour code.
PISTONS: 9.81 compression, hypereutectic (high silicon) aluminium.
CAM: High perf hydraulic roller profile with 235 degree duration (at .050" tappet lift) and .480" max valve lift.
HEADS: Aluminium Corvette with 1.94" inlet valves, 1.5" exhaust valves, D shaped exhaust ports, 58cc chambers, angled spark plugs, screw in rocker arm studs, pushrod guideplated and raised rocker cover rails.
VALVE SPRINGS: Chrome silicon wire with damper (orange colour code).
DISTRIBUTOR:MSD Billet High energy ignition sustem with centrifugal advance. MSD 6 amp and blaster coil.
TIMING SET: Single roller heavy duty chain with steel crank pulley.
FLEX PLATE: 12.75" dia. Automatic trans flex-plate with 153 tooth ring gear.
STARTER: TCI Racing Starter No 351100. Chromed and machined. Mounting block anodized black to match the block colour.
SUMP: Chrome plated version of the stock sump with 1.25" section.
FRONT COVER: Chromed
PULLEY SET: Chromed
WATER PUMP: Short chromed version.
BOLTS: All external bolts Stainless Steel 12 point heads.
Gerry
ENGINE.
PULLEY SET: Chromed
