Can you get Ni-core for a floor like spirit uses? Seem strong and light.
I used cabinet grade 9 ply from Lowe's. Gonna laminate it with glass anyway. No rot if its water tight.
If its totally covered in fiberglass why would it matter if its glued with exterior glue? I would think that the car frame itself would provide enough structure without relying on the plywood floor, or am I totally off base in my thinking?Most birch ply is not meant to be structural plus , unless things have changed , the panels are not glued w/exterior glue..... a/c or b/c would have been a better choice IMO.
Not sure what your referring to .Question for you. What and where did you get that cover on firewall that covers your steering column coming out of firewall? Hope that'.s clear
Thanks,
Johnny
I agreeIf its totally covered in fiberglass why would it matter if its glued with exterior glue? I would think that the car frame itself would provide enough structure without relying on the plywood floor, or am I totally off base in my thinking?
