Welcome to Our Community
Sign Up
Dismiss Notice
A Bit More Progress
Discussion in 'Bodies' started by choppinczech, Feb 28, 2016.
  1. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I have posts on here about making it.
  2. willys t
    willys t
    Expand Collapse
    Nov 23, 2012
    25
    0
    Gender:
    Male
    WOW,you are one talented and gifted person. I cant wait to see it finished.
  3. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks.
    Are you extending your cowl?
  4. willys t
    willys t
    Expand Collapse
    Nov 23, 2012
    25
    0
    Gender:
    Male
    Yes I am, or I should say yes I did.
    Im just about finished with the glass work on the inside of the body.Hopefully Ill finnish it this weekend.
    Im also going to try and post some pictures.I also need to change my avatar,that picture is about a year and a half old.
  5. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    You should make a dvd on how to fiberglass. Your work is unbelievable.
    kcline40 likes this.
  6. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
    That's a very well thought build. VERY impressive.
  7. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks man, but I really do consider myself a "weekend warrior". Just a bit nuts and really stubborn. The bodies I see from Spirit and other vendors really inspire me.
    As I mentioned on Fletcherson's thread, I've started working on the doors. I have to put good sized doors in this. I'm too old and stiff to be climbing in and out of this thing. And the way the seats and dash are, I'd have to literally step on the seats to get in and out.
    The doors will done similar to the rear deck lid. Except this time I laid out the cut with 3M 1/8" fine line tape. Doing it this way leaves the tape's impression in the mold, and then the final part. Making it easy to cut to the shape.
    So, tape and parting boards in place.
    Then wax, masked everything and sprayed PVA.
    Then tooling gel coat.
    And lay up and bracing.
    Then the parting boards are removed and the same process is done on the inside.
    The 1/8" fine line tape is sprayed over and removed. Leaving an exact cut out matched to the molds and final door skins.
    The recipe I used on these door skins was;
    3/4 oz. cloth against the gel coat
    1.5 oz. mat
    12 oz. woven roving
    1.5 oz. mat
    12 oz. woven roving
    2 mm core mat
    1.5 oz. mat
    The thickness is right at 1/4", super rigid and strong.
    kcline40 and kookie2007 like this.
  8. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Are you saving all of your molds so you can build more cars later?
  9. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    No room to store 'em. They're truly one off molds.
    I do still have the seat molds. I might use them in some way to build the area behind them.
  10. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I just wondered. It's a lot of work for a one off project. But I get the labor of love thing, lol! You have demonstrated such excellent talent with this, it seems almost wasteful to have to discard the molds. At least you know for sure that you have one of one!
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    If I had thought about it in the beginning I would have bought them as you finished them and had a bad ass car in Oklahoma.
  12. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Really interesting project. Like the flush side repeaters as well.
  13. Zandoz
    Zandoz
    Expand Collapse
    Apr 6, 2012
    1,142
    134
    Gender:
    Male
    Occupation:
    Retired eccentric
    For about 18 years I custom made office furniture for the company I worked for...everything from stools to wall units. I made jigs for everything, so I could reproduce parts or whole units as needed. I stored them and a lot of my hard woods in an old coal bin at my mom's house...a room that before that was a junk room filled with worthless stuff that hadn't been used for 30+ years. I went to get the jigs to do a book case...all of the jigs and the wood were gone. Mom had someone clear out all that old junk:sick:
  14. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I'll keep this going since it's gonna be quite a long process.
    I got the skins trimmed. The openings roughed out. And the skins fastened in place.
    Now that's what I'm talk'n bout! Some serious entry and exit room.
    Spent a lot of time on these supports. They're plumb to the car's rake and along with more bracing serve to hang the hinges.
    cooter, Indycars, benT and 1 other person like this.
  15. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    So I've been working on these door hinges. The goal here is for the front edge of the doors to tuck inward as they're opened. The same way a daily driver's doors tuck in behind the front fenders. It's a real trick. I don't now if I'm there yet.
    The next step is to temporarily attach the hinges to the door skins and see if I'm even on the right track. Everything bolts together. I can move the pivot point forward or back, and change things as needed.
    The hinge plates will attach to a 3/4" tube frame. Something like this-
    cooter, RPM and fletcherson like this.
  16. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    WOW great engineering .
  17. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks Butch. This part of the build is a real stab in the dark. I've already had to spend a day remaking the hinges.
    No matter how much I plan, I never know until I just get into it to see what works and what doesn't.
  18. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    516
    Gender:
    Male
    Occupation:
    Retired electrician
    Amazing, simply amazing! Your work is in a class by its self.
  19. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks Jim.
    Those are just stacked washers between the supports and hinges.
    Once I get the pivot location set, I'll make something for whatever the space is.
  20. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    If I'm not mistaken that Steve Lang's Willis and his door details?
    You have awesome engineering and conceptual expertise. This is the ONLY 'non standard' Bucket that has ever appealed to me. Everything you have done works and that's a hard trick to carry off. You have solved so many 'so called' problems with a T Bucket, like ease of access, modernisation of the original idea and style; for the next generation of rodders that come after old sods like me. The styling (although not my idea of a Bucket) is second to none and believe me, if had the space, money and time I would be asking you to do a clone for my garage. And I have to add your quality of the workmanship is second to none. There are subtle touches in your execution that will past many by, but those that appreciate art and engineering will always see them.
    Its not much, but my CONGRATULATIONS to you, Sir. I can't wait to see the final car.
    G
Share This Page
SSL Certificate
