Welcome to Our Community
Sign Up
Dismiss Notice
A Bit More Progress
Discussion in 'Bodies' started by choppinczech, Feb 28, 2016.
  1. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Always go the Lambo way and hinge from the front. They do conversion kits for normal sedans which allow the door to move outward first and then hinge forward. Kind think with your skills; you could search for details and then copy the design.
    G
  2. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    Model T s had longer hinge on the bottom.
  3. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    You can have your hinges internal & still clear the body , it won't fold into the cowl but at least the hinges aren't hanging outside....look at CCR hinge/door setup , I shamelessly copied theirs...
  4. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I could hug the inside of the body along with the angle.
    But my doors are so long they'd really flop open. I was wanting them to swing parallel with the ground.
    cooter likes this.
  5. Zandoz
    Zandoz
    Expand Collapse
    Apr 6, 2012
    1,142
    134
    Gender:
    Male
    Occupation:
    Retired eccentric
    Could something be worked out with a hooked hinge similar to a trunk hinge? I've been planning to try to use them because of the way they swing the door away from the opening, for easier handicapped access. But I've not given any detailed thought to how to accomplish that, because that issue is so far away.
    The other idea that comes to mind is to do some kind of speed blister fairings for the external hinges.
    #65 Zandoz, Jun 19, 2016
  6. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    If you were to use a single [ albeit wide] hinge , you could get away from some of the "dropping" [downward swing] of the door.....the hinge would have to be very precise , but I think it would be doable..
    cptn60 likes this.
  7. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    You work in school maintanence , think of the 4" full bushed hinges on a large steel door , 1 of those might be re-purposed..
  8. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I've got this extra bit of body line at the top making it even worse.
    The more I've been getting into it, the less it bothers me to have the outside hinges. The entire front half of the car is traditional so to speak. What with the split wish bones, spring, headlights and all.
    The rear half could actually use a bit also. Sounds weird but as I'm sitting here looking at the car, I'm OK with it.
  9. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    The thing is, you need a long hinge to combat the angle, so you either see it outside or give up space inside. I spent hours staring at mine, lol...
  10. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I've been putting this off for about a year.
    I'll do it like this. Hopefully in a tasteful way.
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I'm trying to do inside hinges too but haven't progressed far enough to see how screwed I am! Thanks a bunch PAL!
  12. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    It is doable if you get the pins right up against the body. I just don't care for the doors on an downward angle as they open.
    I don't know. It's a toss up. That's what makes fab work so much fun.
  13. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I caved and built replica model T hinges. It is after all a T... I tried to use model a type, they would work, but I didn't like the fact that they require a very deep mortise to fit flush because they don't close flat (the hinges) . I don't have room to spare inside at all, so that's not an option for me. With my small doors, I couldn't justify putting a whole bunch of energy into trying to reinvent the wheel, so to speak, especially after getting feedback from several guys who use the originals. I can see why you are trying to do something different, you have a entirely different scenario, with the larger doors and a redesigned body. It's frustrating after putting hours into something to learn it won't work! Been there many times. I used stanly swing away door hinges, flattened, cut them to size, and welded the strap to them. They worked great, but for light doors. For yours, if you wanted to try something similar, I would look for heavier commercial hinges with bearings. They would be pleanty heavy to handle it.
  14. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Yep. Lots and lots of swearing yesterday.
  15. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    The picture is correct. If you want the door to swing parallel to the ground the hinge pins have to be in line and perpendicular to the ground. The easiest way to accomplish this is take out the pins and replace them with a rod that is long enough to go through both hinges at the same time while they are spaced the correct distance apart. This will keep them parallel to each other, now you just have to make them perpendicular to the ground or whatever reference you choose. As in your picture, the measurement from the body to the lower hinge pin will probably be greater than the same measurement at the top pin.
  16. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks for all the replies.
    The pins are in-line, plumb and parallel to the ground. The binding isn't in the hinges. They're nice and smooth. The binding is in the front edge of the door.
    The issue is the difference of space between the upper and lower hinges to the side wall of the body. The upper part of the door is too far away from the upper hinge.
    Without a vertical side wall on the body, the only way to get no binding (at the outer most point) is to keep the vertical line to that outer most point.
    Which in my case is here.
  17. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Back when I was doing this, I could have easily made that section of the side wall vertical. Arrrrrg!
    cooter and Dan Noecker like this.
  18. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    In passenger cars, there is a void that allows the door to overcome those issues. In ours, there isn't enough room to sacrifice for that.
  19. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    So change the front line of the door. Its got to be easier than a whole redesign of the hinges surely????
    I have had to change things that I committed to, defended to the last and argued with friends about until finally I gave in, sat back and thought about it for a while, and decided that sometime we have to go backwards to go forwards. As always JMHO.
    G
    EX JUNK likes this.
  20. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    I have the same problem with the suicide doors on my Model A. I was able to use suicide door hinges from Electric Life to make it work because while opening they kick the door off the body enough that the hinge side lip of the door doesn't dig back in to the belt line when the door is all the way open. I believe the stock CCR hinge does this to a degree as well.
Share This Page
SSL Certificate
