Welcome to Our Community
Sign Up
Dismiss Notice
Almost ready to lay up some bucket bodies!
Discussion in 'Bodies' started by golddredger, Mar 22, 2016.
  1. golddredger
    golddredger
    Expand Collapse
    Jan 1, 2016
    47
    10
    Gender:
    Male
    Acetone works faster than lacquer thinner. End results are the same. Just the accetone costs more and evaporates much faster.
  2. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    yeah we use acetone. We buy it by the barrels. It really isn't that bad buying in the drums.
  3. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
    Should have kept the flathead! Bodies are cheap.
    fletcherson likes this.
  4. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Molds aren't cheap. When I was building cargo trailers to pull behind motorcycles, my largest initial expense was the making of the molds. A trailer body that in raw form cost me 600.00. The mold for that body cost 8000.00 to make. Remember, first you need a plug to make the mold off of.
  5. golddredger
    golddredger
    Expand Collapse
    Jan 1, 2016
    47
    10
    Gender:
    Male
    Oh man materials alone are around $1000 to build a t bucket mold. This bad boy is a couple hundred pounds and no less than 1/2" up to 3/4" everywhere. Not to mention the time invested to lay it up. I bet you would be looking at 4k and up to get one made at a glass shop. I am glad I did it. Flathead was cool and was close to a runner but I can build 2 to 3 small block chevy's for one flathead rebuild. Yes it is just an sbc but that does not bother me. Ok off to wax and buff!
  6. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
    Didn't say building molds to produce bodies was cheap. Buying commercial built bodies is cheap compared to buying flathead engines.
  7. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Ohhh, I must have misread. I thought he traded the f/h engine for a mold, so he could build his own body. I wouldn't trade for a body either. Just sold my 60hp flatty for an obscene amount.
  8. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I don't remember the last time I saw a raw flathead motor. They are pretty scarce around here, like old hemis.
  9. golddredger
    golddredger
    Expand Collapse
    Jan 1, 2016
    47
    10
    Gender:
    Male
    You are correct chopptop, I traded a 48 merc flathead v8 for the mold in the pictures above! I would not have traded for a body only. I gave the flathead, a front axle, heater core, few sbc parts, for the mold, a t bucket body from the mold and a glass radiator shroud.
  10. golddredger
    golddredger
    Expand Collapse
    Jan 1, 2016
    47
    10
    Gender:
    Male
    I still have another 48 merc flathead and i could go pick up 6 tomorrow if i wanted them for $250 each. Also kniw where there is 2 hemis for $800 each. They are around here anytime I want one.
  11. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    It may not be a bad investment.
  12. mountainman
    mountainman
    Expand Collapse
    Jul 4, 2013
    116
    64
    Gender:
    Male
    Occupation:
    and "This is purely to build a couple of cars for my son and I." from you post #8.
    So, what you actually did was trade the flathead for TWO t-bucket bodies and misc. parts. Of course there is the small matter of being able to say that you did it yourself which, like the saying goes, is priceless. :)
  13. Seafarer
    Seafarer
    Expand Collapse
    Jul 5, 2016
    29
    2
    Gender:
    Male
    If you buy metal rollers instead of the plastic ones you can burn the resin out. A small propane torch should work. I don't recommend trying what we used to do. We put a small amount of acetone in a metal coffee can. Small means a tablespoonful or so. Acetone is REALLY flammable so less is better. We hung the roller on the lip of the can. The handle should be not be anywhere near the top of the can - it can burn. We stood back and tossed a match into the can. Got the rollers really clean and I'm still alive to tell the story. We did this outside and made sure nothing else was around that could catch fire.
  14. Seafarer
    Seafarer
    Expand Collapse
    Jul 5, 2016
    29
    2
    Gender:
    Male
  15. Seafarer
    Seafarer
    Expand Collapse
    Jul 5, 2016
    29
    2
    Gender:
    Male
    Sorry for the double post
  16. Clint Curtis
    Clint Curtis
    Expand Collapse
    Feb 13, 2015
    18
    6
    Gender:
    Male
    How thick....how many layers are you going to do? If you lay them up a little thicker than the bodies you can buy, you can probably skip reinforcing your bodies with wood.
  17. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    516
    Gender:
    Male
    Occupation:
    Retired electrician
    My body was made thicker but we also applied a two part foam to the inside of the sides and rear of the body. After that we ground and sanded the foam to our liking and then proceeded to glass over the shaped foam thus making a very strong, solid body. I might also add that before pouring the foam we installed a 3/4" square tube from a 3/16" plate that was attached through the floor to the frame, which was also fiberglass, across the bottom of the dash to a corresponding piece on the other side of the body. This gave us a very strong mounting point for the steering column. The two 3/16" plates that I mentioned earlier are only two of ten mounting points (five per side) for the body. Consequently, we have a completely wood free, very strong body.
Share This Page
SSL Certificate
