Welcome to Our Community
Sign Up
Dismiss Notice
Exhaust leak
Discussion in 'Engines and Drivelines' started by CAB, Sep 8, 2022.
  1. CAB
    CAB
    Expand Collapse
    Jul 31, 2014
    26
    13
    Gender:
    Male
    I have Speedway Sprint headers. Exhaust leaks where collector bolts to header producing ticking noise that echos against the tree line etc. Besides welding the two pieces together, destroying the chrome finish, how can I stop the leak?
  2. CAB
    CAB
    Expand Collapse
    Jul 31, 2014
    26
    13
    Gender:
    Male
    I believe I used incorrect terms here...the leak is where the side pipe slides over the collector. There is one bolt used to clamp them together, which doesn't seal them up very well.
  3. Spanky
    Expand Collapse
    Jul 29, 2016
    3,086
    2,528
    Gender:
    Male
    Try wrapping some tape around the collector and then sliding the side pipe over the tape. It will probably burn off, but it will tell you if that's the source of the "ticking" noise. Then you might be able to find some metal tape that won't burn off.
  4. CAB
    CAB
    Expand Collapse
    Jul 31, 2014
    26
    13
    Gender:
    Male
    Definitely leaking from around the bolt that's used to clamp them together. Poor design altogether. May have to find a one piece header and side pipe if available. Nothing ever simple.
    Spanky likes this.
  5. Spanky
    Expand Collapse
    Jul 29, 2016
    3,086
    2,528
    Gender:
    Male
    Is it possible to insert the collector deeper into the side pipe to minimize the leakage?
  6. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,864
    781
    Gender:
    Male
    Occupation:
    J.B.Weld?
  7. CAB
    CAB
    Expand Collapse
    Jul 31, 2014
    26
    13
    Gender:
    Male
    It's in as far as it fan go, about 3 inches or so I tried putting JB weld where they meet
  8. CAB
    CAB
    Expand Collapse
    Jul 31, 2014
    26
    13
    Gender:
    Male
    JB Weld is an epoxy.
  9. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    I use Permatex High Temperature RTV Silicone on my motorcycle's exhaust between the head pipe and the muffler. Put a light film on and snug it up, wait an hour or two till it drys and then tighten it up.
  10. CheapT
    CheapT
    Expand Collapse
    Apr 28, 2022
    250
    135
    Gender:
    Male
    Occupation:
    Fundraiser - Please Donate to Keep This Site Going
    Spanky likes this.
  11. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    I was also going to suggest hi temp silicone sealant. I use it on my Model A exhaust manifold. It’s ok for thing costs. Big globs don’t work as well. It’s worth a try.
  12. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    417
    237
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    Try finding some muffler putty, apply it to the joint B4 sliding it together, it expands to fill the gap when the exhaust heats up..
  13. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    The hi temp rtv works well. Another thought: can you replace the connector with a stainless band clamp? They seal well.
  14. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,534
    1,139
    Gender:
    Male
    Occupation:
    Information Technology (IT) 15yrs, Then Retired
    Most people don't have trouble with this connection, could it be that they are not perfectly round. Try taking them to a muffler shop and see if they can use an expander to lightly stretch them and make them round again.
    Putting a sealer or tape is only covering up the problem.
  15. Ron Bennett
    Ron Bennett
    Expand Collapse
    Aug 8, 2022
    8
    4
    Gender:
    Male
    You may look to see if the split in the extension is wide enough. On mine when it was clamped as tight as the bolt would allow it completely closed the split and pipe was still loose. Used a cutoff wheel and made split wider and problem solved. Probably not your problem but maybe should be checked.
    Spanky likes this.
Share This Page
SSL Certificate
