Front hydraulic shocks for a Spirit chassis...
My shocks are Pete & Jake's shorties. The measurements are the same as the SM 300s here. I mis-measured when I designed the mounts and they ended up about 1" too short for these shocks. So far, it hasn't been a problem.
I wonder if the old 48 Plymouth shocks would work, or was it Merc shocks? Dang, now I'll hafta spend a few hours checking RockAuto until I find the part number again...
IIRC, they are the exact same as the P&J Shorties, just not chrome.
Could you post the part numbers when you find them?
Thanks dirt t
I was a little off, and that's not the first time anyone has said that...
1949 Plymouth -
5752 has 5/8" X 1 5/16" eyes, compressed length of 8.625" and extended of 12.750", has a 1-3/16" bore and fits 47-54 Willys Jeep and 1949 Plymouth. It is a Sensa-Trac Passenger
555002 has 5/8" X 1 5/16" eyes, compressed length of 8.625" and extended of 12.750", has a 1-3/8" bore and fits RV and is a Gas-Magnum RV.
http://catalog.monroe.com/catalogPa...atalogCode=monroe&locale=EN&loadStatus=ACTIVE
http://www.rockauto.com/dbphp/prt,904,5752
Not as pretty but a good bit less expensive at $16.83
That's what I use and just cut off the upper dust shield, then paint.
Here is how I did mine. I coppied lee's frame brackets and made new spring purches with the shock brackets added on. Give me you thoughts good or bad.
Thanks
Terry
