I'll chime in. I run a front panhard on my car. I do believe they are needed. On a typical transverse spring front end, the spring is attached to the axle with shackles on each end. The shackles are nothing more than a hinge. With a hinge on both ends, the axle will shift. The reason a panhard bar is recommended with cross steer is that the steerring forces will cause the axle to shift sideways. So the simple fact that Everyone is agreeing with using one on cross steer set ups, shows that Everyone agrees the axle is capable of shifting sideways. Now apply just a little common sense.... If you can exert enough force by turning your steering wheel, to cause the axle to shift sideways, don't you think the forces from turning at speed will too ? Yes they will. And to add to it, you also have the stored energy from the spring, being released. A good bump, and fast turn, can make for a wild ride. A panhard bar is a very simple item to install. And all the hype about it shifting the axle itself because it moves in an arc is just BS. Yes the bar does move in an arc, but with a moderate length bar, and the small amount of travel these cars have, the arc is small, and is controlled. Unlike the loading/ unloading of the shackles and spring in mid-turn.
