Welcome to Our Community
Sign Up
Dismiss Notice
Mallory dizzy conversion
Discussion in 'T-Bucket Electrical System Articles' started by Jerry Crawford, Jun 26, 2016.
  1. Jerry Crawford
    Jerry Crawford
    Expand Collapse
    Jun 1, 2016
    19
    2
    Gender:
    Male
    Occupation:
    Retired
    Hi,
    I have a Mallory dual point distributor 2548201 on my blown SBC. I would like to convert to electronic
    but the base plate on this dist mounts with 2 vertical screws not 2 horizontal screws that go into the sides.
    Pertronixs does not have a kit for that type of base plate.
    Anyone have any recommendations for an alternative ? Would like to keep the Mallory for nostalgic look.
    Instead of going to HEI
  2. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,682
    873
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Do you have a picture of what you are talking about. Could not find that part number. Maybe make a new base that has the clamp style hold down?
  3. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    I "think" mallory made a uni-lite conversion for those , since mallory is gone they might be hard to come by, maybe e-pay ??
  4. Jerry Crawford
    Jerry Crawford
    Expand Collapse
    Jun 1, 2016
    19
    2
    Gender:
    Male
    Occupation:
    Retired
    The base plate I reference is the plate the points screw into ,not the distributor base which has the hold down clamp,
    Regards
  5. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    574
    207
    Gender:
    Male
    Occupation:
    Carpenter
    What series is it, not just the part#
  6. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,682
    873
    Gender:
    Male
    Occupation:
    Just what the Dr. ordered Henry T.
    Buy the conversion kit that will fit inside the Distributor and mount it by adding 2 tangs/spot welded under the bottom of plate in correlation to the old plate.and/or modify the plate/grind to fit inside the body. There shouldn't be anything in the way for the tangs. It can be done!!
    Pertronixs modules mount in the same way as points do on top of the plate. Don't see why it wouldn't work.
    You could not use a standard HEI distributor with the blower manifold and intake system. I don't there is enough room.
  7. Jerry Crawford
    Jerry Crawford
    Expand Collapse
    Jun 1, 2016
    19
    2
    Gender:
    Male
    Occupation:
    Retired
    I believe the first two numbers refer to the series number so this would be a series 25 ?
    The number 2548201 is the only number I can find on the dist along with the points gap and dwell numbers
    I checked with Pertronixs and while they advertise a ignitor system for a series 25 it must have the horizontal attached base plate not the vertical attached plate.
    I did find another conversion called Hot Spark but not enough info on the company or reviews to see if they are any good.
  8. Jerry Crawford
    Jerry Crawford
    Expand Collapse
    Jun 1, 2016
    19
    2
    Gender:
    Male
    Occupation:
    Retired
    Thanks HenrysT
    I may give that a try. The blower is a little 471 so more room for options
  9. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    574
    207
    Gender:
    Male
    Occupation:
    Carpenter
    Take a few pics and send them to Pertronixs to see what they say.
  10. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,875
    901
    Is the new kit a Hall effect? They are pretty rock solid and simple, imho. If it wasn't overly pricey and didn't require destruction of your prized nostalgic distributor, I'd likely take a chance, fwiw. I looked at the hot spark site, it is a Hall effect sensor and they are rated for marine applications. I wouldn't have any reservations trying one. It's nice that they mount in place of the points too.
    Spanky and Jerry Crawford like this.
  11. Jerry Crawford
    Jerry Crawford
    Expand Collapse
    Jun 1, 2016
    19
    2
    Gender:
    Male
    Occupation:
    Retired
    Ordered it
    Thanks
  12. Francis Blake
    Francis Blake
    Expand Collapse
    Jan 26, 2008
    1,280
    50
    Gender:
    Male
    That is one I am going to save
  13. volksnut
    volksnut
    Expand Collapse
    May 26, 2012
    85
    41
    Gender:
    Male
    I used the Mallory E Spark in mine, works great
  14. Spanky
    Expand Collapse
    Jul 29, 2016
    2,864
    2,182
    Gender:
    Male
    Using the Pertronix Ignitor in my original style distributor with great results! :thumbsup:
Share This Page
SSL Certificate
