Welcome to Our Community
Sign Up
Dismiss Notice
Minimum wheel diameter to clear GM brakes
Discussion in 'Brakes' started by TheYeti, Nov 10, 2021.
  1. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Hello. I found a nice set of 14" slot mags for my front wheels to match the back which are 15"
    Will these 14s fit over the gm 11" rotor (on 37-48 axle) with the GM "midsize" caliper?
    [​IMG]
  2. iroct
    iroct
    Expand Collapse
    Aug 21, 2008
    135
    29
    Gender:
    Male
    I had to grind the caliper on the ones on my avatar
  3. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Don't have an answer to your question, but be concerned with backspacing also.
  4. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I think you will have issues. I put disc brakes on a skylark and the factory 14” wheels wouldn’t clear. You just have to try and see with your combination.
  5. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    I run 10" Mustang 2 rotors with my 14" fronts - no problems. But 11" rotors - calipers will probably interfere with the wheel!
  6. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Damn. Well I'll give it a try anyways. Those front slot mags were free
  7. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    Bolt them on then spin the wheel. You'll know immediately. If they don't clear , they might not even bolt on. Hope this helps.
Share This Page
SSL Certificate
