As for the frozen North, if you find a map and look to the right of Boston you will see Nova Scotia. So I'm East. Therefore my winters aren't as bad as those folks "Up North",
uhhh..... okie dokie.
Russ
Russ.
My ecu is over 15 years old and is not a sequential fire system It fires in pairs. There is no limp mode on it. I can only assume that Greg at Kinslers knows what he is talking about but I will check with him again. As you say one 02 sensor in one pipe of an 8 pipe system is not really that good at averaging.
Gerry
I think he means "open loop"...
I don't know about his computer but the stock EFI system in my firebird has a "open loop" and "closed loop" mode. When its in open loop is ignores the O2 sensor and just works off spark and fuel tables. If there is no o2 signal then it just stays in this state. When in closed loop it takes feedback from the O2 and makes adjustments to get the AFR correct. It runs in open loop for a wile until the engine warms up..
It also has a "limp mode" but this is to just get the car off the road and parked. If the ECU detects that the CPU is dead or has some flaw it stops thinking. It defaults to an analog circuit that uses the signal from the the distributor to fire the coil and injectors. There is zero spark advance and no adjustment in the fuel.. the engine will just barely run so you can pull off the road to a safe spot.
Is the radiator under the cowl ? :jester:Well I finally got the purge tank finished and installed today. I had to relocate a few items to make room for everything, and it's really filled up the engine compartment now, but I'm happy to report that the system works great!!. with the cap off the new tank I can see good circulation and the purge spay is spitting out air to beat the band after the freash refill in the radiator.
Russ
Your dealing with police officers for this inspection? Be sure to bring donuts.
Bob
Hey Russ,good luck with the Policing obficers and yeah bribery goes a long way not that I believe you need to do it,but hey letz get on his best side straight off.I lke your wiper also but can you take some more detailed photos of your top frame at the windscreen end for me please.
