I am considering aluminum, but not to that point yet.Got the new body from Ron and would like to put in a floor of something lighter that 5/8" plywood. My other body weighs a bunch. Any ideas?
I just know that when I helped Thomas build his Spirit bucket , the body was lighter and it took 5 guys to fit my wooded up body on. Oh that Coosa look great but that price is killer.
You're comparing apples to oranges , unlike boats , these cars are not [hopefully] immersed in water , if you get caught in the rain , the little bit of water drains/dries out quickly , any holes can be sealed during the glass process , using marine ply is more than sufficent , both in water resistance & strength , saving less than 10lbs. is not very cost-effective , there'sw been literally thousands ofthese cars built w/ wood floors & unless left out in the weather constantly , I can't believe "wood rot" would ever be a problem nor have I ever heard/read it being mentioned....
My floor in the bucket now is fiberglassed on both sides and the bondoed and finished and painted. No trouble. Just looking for lighter.
Old drag race saying was "every 100 lbs. is worth a tenth" That being said , 10 lbs. is worth a hundredth , nothing I'd spend extra $$$ on , LOLMy signature spells out my approach to my project...
“Simplify, then add lightness,” -- Colin Chapman
For the typical T-Bucket with a monster motor, giving a second thought to the weight of individual components is not a high priority. In my case, with a little 150 or less horsepower V6, weight is the enemy. Where ever possible and affordable I'm going with light weight components. Other than going with an aluminum floor, with the associated fabrication, the composites are the best bet I've found for flooring...and other typically wood components.
On it's own, assuming it was a drag car being built, the weight savings of the composite alone would not make the extra cost worth it. But as a part of a concerted effort to reduce weight, those 5, 10, and 20 pound savings add up to a real advantage...especially on the street.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere" -- Colin Chapman
It's hard to argue with Chapman's philosophy of building light weight cars...countless sports car wins, 7 Formula 1 constructor titles, 6 driver championships, winning the Indy 500, and 60+ years of building performance street cars is nothing to sneeze at. The modern Formula 1 and Indy cars are direct descendants of his approach. Lotus' current low end street car, the Elise, weighs under 2000 lbs, with a now days tiny 134hp engine. This works out to around 14.8 lbs per hp. The Elise manages 0-60 times of 6 seconds.
My car's target weight is around 1500 lbs, with a similar around 135hp engine. This works out to around 11 lbs per hp. I know my car will never be a match for a Lotus Elise...straight line or in the corners...but it should be no slouch as a casual cruiser on the street.
AMEN !!Just me but I'm a HP whore, I don't think you can have too much HP. It can be controlled by the right foot. Just worry about hooking it up.
700 HP in a 1700 Bucket is just about right.
