Welcome to Our Community
Sign Up
Dismiss Notice
Questions reguarding steering brackets and shocks
Discussion in 'Suspension' started by irishluck, Jul 9, 2021.
  1. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Getting my axles setup and wanted to get the front one finish before i go back to the rear.
    Im questions how im suppose to put steering brackets on my spindles as they look like there wont be enough room between the spindle and axle. Ill attach pictures.
    2nd question is about front shocks. I had the lower shock mount that bolts on the bottom of the batwing but it wont worl due to my dront axle not setting under the frame. So i purchased some shackle shock moun
  2. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    20210709_184502.jpg 20210709_184510.jpg 20210709_184506.jpg 20210709_184529.jpg 20210709_184524.jpg 20210709_184548.jpg
    rbsWELDER likes this.
  3. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    First try mounting the caliper brackets on the top bolts. Be sure bleeder is still up. The lower shock goes on the bolt holding the radius rods to the axle with bolt going to front. The shackle brackets are not needed. You will need a top shock mount.
    choppedtop likes this.
  4. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Normally the caliper is on the top rear of the rotor. That may free up some room for you.
  5. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    The caliper brackets only fit on the bottom of the spindle. They wont fit on the top. The top is to big and the bracket wont seat around it.
    Yeah I know where the shackle shock mount goes, Im just worried cause I dont think there is going to be enough room/clearence for it. I have the upper shock mounts already. Its the shock mount and headlight bracket.
    But I have to use the shackle shock mount. The one in the picture that is on the right hand side, will not work. If I install a shock on those, it will hit the batwing.
  6. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    I dont think I bought the right front brake kit for my car -_-.
    I think the caliper brackets that were in my kit are for a stock ford spindle. Speedway says that it should work on my spindle I have (all purchased from them on the same order) But I dont think thats accurate after looking at the kit online again.
    This is what i purchased.
    Brake Kit 1969-77 GM Caliper to Early Ford Spindle, Ford B-P
    Speedway 1928-1948 Ford Forged Spindles Only
    This is the kit I think I should of bought with those spindles.
    1937-48 Ford Spindle Disc Brake Kit, 5 on 4-3/4, Big GM Caliper
  7. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Did you try bolting the bracket to the top 2 bolts with the caliper to the rear of the axle? That is how they should mount. I believe you have the late spindles. I have the 37/48 kit with the large calipers.
    Okay I just re-read your post about already trying them on top.
    #7 choppedtop, Jul 9, 2021
  8. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Yeah I put the links of the 2 kits I got. I think I got the wrong kit....
    Im now wondering if I can modify the caliper brackets to work
  9. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    G'Day Irish, you should be able bevel the front and back top corners of the spindle and ease the same area on the brackets to get a bit of clearance for a nice fit.
    Regards,
  10. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    591
    218
    Gender:
    Male
    Occupation:
    Carpenter
    Can you take the caliper bracket off and flip it to how its suppose to go and take a pic of the interference location(s). Looking at the instructions, the bracket is suppose to mount to the top 2 bolts and the rear bottom bolt locations. Before you do anything, you can always call Speedway and tell them of your problem, your probably not the first one to run into this. I think the difference between the two kits is more the matter of bolt circle (Chevy vs Ford)
  11. Island Girl
    Island Girl
    Expand Collapse
    Jul 21, 2018
    1,072
    1,139
    Gender:
    Female
    Occupation:
    Manager
    The kit you got says it's for the spindles with an integral cast steering arm, . . . From the description:
    • Designed to work on 1937-48 Ford spindles that have the cast on steering arms. It will not function correctly when used on a spindle that uses bolt on steering arms and would require alteration
    The one you think you should have gotten, is the one you should have gotten . . . Will Speedway exchange it?
    lincolnuT and Spanky like this.
  12. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    I think this is exactly what im gona have to do.
    My spindles use bolt on steering arms. The kit i got i think is for cast steering arms
  13. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Ill get some pics of it trying to bolt to top to show the clearance issue for you all.
    Im still stuck on the issue that i have no way of attaching shocks to this axle. In the last pic of the original post it shows the 2 different shock mounts i have. Neither one of them will work with my setup.
    Any thoughts on how to attach some shocks?
  14. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Ive attached some images of the clearance issue with the caliper bracket.
    Also I have attached 2 images that shows that the shackle shock mounts wont work on my front end either.
    Thoughts?
  15. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    Sure nice to see several nice clear photos, makes it so much easier for others to help !!!
  16. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Can you swap the spindles right to left?
  17. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    I try to get the best photos I can. I see lots of people in all these forums try to post pics and you cant even tell what it is lol
    Indycars likes this.
  18. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Im sure I could but would that put the caliper in the front instead of the rear?
  19. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    What if you used this type of shackle bracket?
  20. irishluck
    irishluck
    Expand Collapse
    Nov 11, 2018
    87
    13
    Gender:
    Male
    Mm going in the right direction in figuring something out there but that still wouldn't work. It wouldnt clear the batwing and Id still need it to stick out about an inch or so to keep the shock bushings from not being crooked.
    That bracket almost looks like its about 45*. If there was one that was at a 90* angle, that might possibly work.
Share This Page
SSL Certificate
