VroomKrazy
I have the 3 position shock mount for the rear axle from Speedway. This weekend I removed the shocks and notices that where the 1" diameter spacer bent the metal in the middle of the mount. How do I solve this problem. Do I make a bigger diameter spacer, add a 1/4" backup plate in the shock mount, or both. This the mockup rear axle, so I want the fix the good rear end before it is installed.
Thanks
VroomKrazy
Thanks
VroomKrazy
