old round fart
I tried using my iPad for this post so I don’t have a compressor on it I can figure out. It was late and I was tired but was excited and wanted to post. I’ll work on it after my exercise today.
This will give me close Ackerman steering.
Just a few numbers to muddy the water.I had a 1976 1 ton Chevy crew cab. Got to having problem eating left front wheel bearings. Usually killed the spindle surface under the inner bearing. Would go get a wrecking yard replacement. After going through two spindles I got tired of worrying about being on the road without a spare. Went down to the Local Pontiac dealers parts department and pricing a new one I realized there wasn't that much difference in price so I told him I needed it. He pulls on up but it had a 3'4 Ton part number and cheaper then the 1 ton. Looked at it and it measures exactly as the 1 ton I brought with me. Come to find out they used the exact same spindle on a 1 & 1/2 ton trucks no matter what wheel base you had. So, to answer Neshkoro's question of
1/8” or 6”?
117.5 in (2,984 mm)
131.5 in (3,340 mm)
164.5 in (4,178 mm)
I do still have a 1 Ton single cab with a long flatbed and will measure the WB next trip home. Evidently GM wasn't to concerned about it. I drove both of those trucks like sorts cars with the current one being in the mountains. I have read in several road and circle track racing that the Ackerman length was moved both forward or rearward to make the car turn better depending on what they wanted to do. Just getting it close in all probability is close enough. Take this for what it is. Just more muddy water to filter though the confusion. Have Fun!
George
Makes sense to me. I think you described it to be the Steering arm-to-tie rod joint is on the line from king pin-to-rear end line.
Just curious, is close 1/8” or 6”?
