Birth of Long John
Air flow...I bet a louvered panel would be fine. On a cool day cruising my fans don't even come on. And they usually run at less than 100% unless it's a hot day.
I'll be very interested in your experience. Did I give you this link: Cooling secrets
Some know-it-all has a few good ideas. Note the coolant mixture.
Made some progress on my steering today. Not finished I still want to box in the arms and bellcrank arms and mount but this will give you theF1F117B3-7480-41E9-8ED0-1982FFED41F7.jpeg F1F117B3-7480-41E9-8ED0-1982FFED41F7.jpeg 12783FB5-C83A-4A47-8252-3F228F018BEA.jpeg idea if my video works!
Video needs some kind of extension so I’m a lost ball in high weeds. My computer man will be down for a while so y’all make up what it does! Lol
Bought a 2 ton motor hoist from Horrible Freight today. I thought 2 tons was lifting capacity. After unloading it I think that is shipping weight! Had to open it in the truck and take it out of the boxes a piece at a time.
Got the rack mount figured out. I have about 1/4” clearance to the oil filter but that is as good as a mile. Had to go to a double u-joint to get to the firewall where I wanted to go. Also got the brake master mount tacked. It’s REAL close to the 4l80e trans. Have a different pedal coming to see if I can have a smaller hole in the floor. 36AE75A3-7068-484A-9152-307498AD26F2.jpeg010C7F9A-5915-438F-9682-C1E95F7EE50C.jpeg
Like we were talking yesterday @old round fart, a different MC would free up
some room. Below are the dimensions of my MC.
Bore Dia. = 1.0"
BE3C712B-5853-4498-BE67-A97C92740D4E.jpeg My cap is 3 1/4” but the critical dimension is the output boss. Mine is 3 3/4”wide and your picture appears the bosses stick out past the cap a lot more than mine. Thanks for checking.
Just got the frame set to ride height with rear end under it andMAN! This car is bitchin’ ! I should have a roller this week. Spindles on the way after mod to fit wire wheels. Axles to be narrowed here. Wheel studs be here tomorrow. I started with the motor purchase May 16, 2016! I think I’m going to beat Sir Spanky’s time line.
I HAVE to beat it. I’m 77 years old! Lol. Worked on getting my MiniSplit heat and air put in this morning with the help of Indycars. I spent more time looking for stuff than working. I piled up stuff to make room for the install and was even more unorganized than usual.
A tad is a little less than a scoch. After I aired up the tires I think the clearance will be fine. I still can’t clear most road kill but it looks cool. Found out I have 28 spline axles but my cut to fit are 31 spline! More money but I get to pick ratio and posi if it fits the ever expanding “budget”. Quotes makes it adjustable!
