CCR frame plans
Not sure I understand your question but the double RR bracket is the standard CCR mount. The four single mounts are for using a Jag rearend or if you want to do something different.
Those double mount brackets seem to be designed for the long radius rods that CCR designed and sells.
I'm building to Youngsters plan so my radius rods are much shorter and therefore I need to use the single mounts.
That's right Craig. Different therory, different drummer....
RPM said:
Vince, we keep all those CCR brackets cut and in stock. Most are just $10.00 each. If need some give us a call. 865-932-7541
I sent you an email if your address is correct on this forum.The price sounds good u just would like to know what the shipping costs are ok?
Thanks, Vince
