CCR rear spring
butch27
I have a CCR arched spring under my "T. It is only 1-3/4" WIDE as compared to 2-1/4" stock ones. It still rides rough. I need to know what the spring pounds for this is and why they are only 1-3/4" wide. My car weighs around 1750 lbs.
I think the narrower spring is softer than original spring. You may be able to take out a leaf or two and/or put poly shims between the leaves.
I have poly shims between leaves. TOTAL use to sell some clear WITH a lip on each side. Great stuff. Speedway's doesn't have the lip.
CCR has the clear stuff with the lip on each side ...
