Also try Grainger, Enco, and Fastenal. Anyplace where they sell machine shop tools you can get any tap made. Let me also say this, when you tap, you go thry the hole the first time heavily cutting threads, I normally use tapmagic or some type of heavy cutting oil. Usually the 2nd pass into the same hole with another tap, (ususally the next smaller tap size....usually a H-2 instead of a H-3)as not to overly enlarge the threads but to 'clean' the threads out, but I normally on the 2nd pass us a tapping wax, its thick and sticky, as the H-2 Cleans, the 'giblets' that are cut out and off will stick to the tap, and be cleaned off.
All taps made are made with these designations, H1-H5. H1 being the smallest and H5 being the largest. When you drill out a hole and normally tap it....your getting a H3. You can adjust your thread 'Fit' by using these to make your threaded fit tighter or looser.
Be sure to clean off your taps but leave them oiled, and don't let them bump around, just like your files....
