cooter
What do you mean "cant get RR 90° to floor." You talkin bout on rear axle?Looking good Cooter , your flying. I cant get my RR rod brackets exactly 90 degrees to the floor. What did you come up with on yours.
Should i add the tubes? Im useing the speedway offset lower mount on coilover.The lower coil-over shock housing brackets normally have tubes welded in place for the bolts to pass thru. Those may be for a shock only or are just missing the backing tubes?
View attachment 11206 View attachment 11207
